View SLPP Guard Status
View current SLPP Guard settings.
Switch:1#>show slpp-guard
SLPP-guard Ethertype: 0x8102
Port Interface
Port Link Oper SLPP-guard State Timeout TimerCount ORIGIN
1/1 Up Down Disabled N/A 60 N/A RADIUS
1/2 Up Down Enabled N/A 120 N/A RADIUS
1/3 Up Up Enabled Monitoring 60 N/A RADIUS
1/4 Up Down Enabled N/A 120 N/A RADIUS
1/5 Down Down Disabled N/A 60 N/A RADIUS
1/6 Down Down Disabled N/A 60 N/A RADIUS
1/7 Down Down Disabled N/A 60 N/A RADIUS
1/8 Down Down Disabled N/A 60 N/A RADIUS
1/9 Down Down Disabled N/A 60 N/A RADIUS
1/10 Down Down Disabled N/A 60 N/A RADIUS
1/11 Down Down Disabled N/A 60 N/A RADIUS
1/12 Down Down Disabled N/A 60 N/A RADIUS
The TimerCount column in the preceding example output indicates the time, in seconds, that elapses after SLPP Guard disables a port. When the value TimerCount value equals the Timeout value, the switch re-enables the port.
Variable definitions
Use the data in the following table to use the show slpp-guard command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
